I have a 25HP Johnson outboard on a boat my dad gave to me. He bought the motor used and it has no serial plate.
It is a long shaft motor with electric start and remote controls. Attached is a picture.
The carb says "HQ 432700"; soft plug on the head says "G303961B"; right side transom bracket is stamped "19101" and "188"
I need to replace the water pump and am also having trouble getting the lower unit off. Bolts and nut are off, shift linkage is disconnected, and the loose threaded part and plastic bushing are on the lower rod.
Thanks for any help
Thanks for any help
