The Honda outboard has an electric starter built in. It has an internal alternator to charge the battery. There is a heavy 3-pronged cord that plugs into the back of my sailboat. This cord leads directly to the battery. The rest of the electrical system runs off the battery.
This system has been working fine for years. The one think I can think of that may be different this year may be that perhaps I plugged in the 3-pronged connector incorrectly. Although, I would imagine that these connectors are keyed to prevent this from happening. I remember one of the prongs was wider than the other two, but that none of the prongs were angled like I remember in my youth of AC shore connectors. I will inspect the connectors today and see if making this connection icorrectly is even possible to do.
If it were the rectifier, I am assuming this component would be built into my outboard, along with the alternator? Right?
OK. I have more information.
I went out to the boat to ensure I had the power plug oriented correctly. Yes, it appears there is only one way to orient the plug, one prong is of a different width.
I then checked the battery power using an ohm meter at the cigarette lighter outlet. It read 11.7 V. I have been trickle charging using a solar panel. I then tried starting the motor with the electric starter. Like all this year, it barely turned the motor over, but it did start after a couple tries. In years past, there was plenty of power to turn over the motor with gusto.
I then let the motor idle, and checked the power again. It read 15V (!) I was somewhat surprised, I thought it should be charging at 13.25V. I then went to increase the RPMS and the motor died. At that point I could not start the motor again with the starter. So I attempted with the manual pull cord. In years past this easily started, but not this year. I pull many times while adjusting the throttle, but to no good. It would not start either way.
I was hoping to run up the RPMS and see what the alternator was putting out. Additionally, I really hoping to put the motor drive into Reverse to see what the alternator was putting out. Since this was the failure mode to start with.
Ugh!
