ironworker
I have a 1983 35hp Johnson that I just got. I have put a new carburetor kit and water pump kit in it and It will fire up with the choke shut. it does not want to stay running at idle, will run when revved up, but not at idle. the low speed needle valve looks good, do not know what else to do. I am a novice at outboard motors and since started working on this motor have learned alot. but have gotten to a point where I am not sure what to do. Anybody got time to help me out. I also inherited a 25 hp Johnson that the motor is froze up, can I use the parts off of it to use on my 35hp? Now the second problem is it has a real bad miss? when running at speed, almost like I am hitting a log or something, does not lose speed but it does occur reguraily. Have no clue what that is. any help on these things would be greatly appriecated.
