Dave, I'm glad to hear that Gary has the part and is willing to sell it to you.
A couple of things:
Yes... the vice rods threads are a double Allen or Acme.... and likewise with the threads within the cast iron clutch component.
The cast iron clutch component is designed to slip when the drive is being pushed back down while the vice rod is retracting upwards.
The upward force causes the cast iron part to separate and release from it's brass counter part... of which is the worm ring gear.
NOT designed to slip if the electric motor is raising the vice rod
without the Hartman microswitch in the loop.
The micro switch eventually becomes depressed by the upward moving vice rod (drive going full down).
When depressed, the switch interrupts the motor's Negative circuit just prior to the clutch component reaching the end of the threads.
If the clutch was to reach the end of the vice rod threads....., it will break the cast iron threads off.
People will often run the electric motor independantly from the relays and micro switch for testing... and that's when they get themselves into trouble.
