3 fasteners I think.---------2 bolts on the side and a nut / stud around the front.
Thanks for your help. Actually on the I boats forum I found an older post addressing the same issue. A lieutenant Commander with forum name Cofe Listed five steps with photos that was just the info I was looking for. There is another bolt hidden behind the solenoid. The solenoid has to be removed from its bracket to get to it. Who'd have thunk it? I purchased the repair manual but so far it's been a waste of money. Why couldn't the manual have the info Cofe offered.
What manual did you buy ????
I happen to have that manual and you are right, it doesn't say anything about your model. It does say how to get the older 40hp starter off though. AND, it also missed a few screws!! Like I said, it is generic and does contain errors. But it also includes a lot of stuff you won't find in the factory one.
By flap, you mean the choke? Sure sounds like a plugged or restricted high speed jet. Did you check it? I assume you will say yes....everybody does.
High speed jet is found in bottom of the float bowl.----9 out of 10 folks are not aware of it when working on these motors for the first time.-------They often ask " why does my motor not run " after cleaning the carburetor 3 times !!!
