Hello,
New to forum, would be grateful for knowledgeable feedback. Engine sn IC030035.
runs in my opinion somewhat rough at idle, can hold rev at 5000+rpm out of water with muffs on.
when dropped in water, runs "rough" can't get above 2300 rpm, 3 beep horn.
have replaced: fuel in tank, primer bulb, fuel filter in plastic viewable case, cleaned fuel injectors, replaced spark plugs.
whats next in the most logical least expensive order?
Extra info, not sure if this is a cause or not..problems began after putting non ethanol in 5 gallons... Don't think that was it. Might have over filled oil past max fill line....could be a combo problem.
fuel I pulled out had a caramel tint to it-I did sea foam it prior to draining. My marina uses 89non ethanol. Bought the boat used last November, they said well maintained by family member who worked at authorized svc center..
ran perfect the week before I put garage gas in it.
