Tachometer not working, also flushing engine
czbill
I just bought a 2004 Aquasport with a 175 Johnson outboard. The engine runs well, but the tachometer doesn't move. It is a Faria tach with indicator lights built in, I would like to keep it stock if possible. Where should I start looking?
Also the boat will be on a lift, I can't get to the leg to put a flushing muff on it. Does this engine have a flushin port? If so, where is it located?
What year is that 175hp Johnson?
Normal procedure would be to make sure that the polarity of the battery to engine is correct first, then to test the rectifier, the procedure of which differs depending on whether the engine has a water cooled voltage regulator/rectifier assembly... OR... the smaller three wire rectifier that is attached with two bolts.
I suspect that your rectifer would be the larger of the two.
It is a 2004, 2 stroke. Using the factory battery cables correctly hooked up.
The reason I stated to check the "polarity" is that it is possible to accidently charge the battery backwards... and it does happen.
That engine would have the water cool voltage regulator, rectifier assembly. You could do the following test.
(Testing Tachometer With Water Cooled Regulator/Rectifier)
(J. Reeves)
A quick check is to simply plug in a another new tachometer as a piece of test equipment. If the new tach works properly and the old tach didn't, obviously the old tach is faulty.... but usually boaters don't carry around a spare tach (see below).
A faulty rectifier wouldn't damage the tachometer, the tachometer simply wouldn't work. This is due to the fact that the tachometer operates off of the charging system and the rectifier converts AC voltage to DC voltage, enabling the charging system. A faulty rectifier disables the charging system, and the tachometer simply doesn't register.
However.... those water cooled regulator/rectifiers that are used on the 35 ampere charging systems (and some others) bring into play a different type problem, and as you've probably found out, they are really a pain to troubleshoot via the proper procedure. There's an easier way.
The tachometer sending/receiving setup operates off of the gray wire at the tachometer. That same gray wire exists at the engine wiring harness which is connected to the engine electrical terminal strip. You'll see that there is a gray wire leading from the regulator/rectifier to that terminal strip, and that there is another gray wire attached to it. That other gray wire is the wire leading to the tachometer which is the one you're looking for.
NOTE: For the later models that DO NOT incorporate a wiring terminal strip, splicing into the "Yellow Wire" mentioned will be necessary.
Normally the Gray wire leading from the tachometer is attached at the terminal strip to another Gray wire which leads from the water cooled voltage regulator/rectifier...... remove the gray wire that leads to the tachometer. Now, find the two (2) yellow wires leading from the stator to that terminal strip. Hopefully one of them is either yellow/gray or is connected to a yellow/gray wire at the terminal strip. If so, connect the gray wire you removed previously to that yellow/gray terminal. Start the engine and check the tachometers operation, and if the tachometer operates as it should, then the regulator/rectifier is faulty and will require replacing. If the tachometer is still faulty, replace the tachometer.
If neither of the yellow wires from the stator is yellow/gray, and neither is attached to a yellow/gray wire, then attach that gray tachometer wire to either yellow stator wire, then the other yellow wire, checking the tachometer operation on both connections.
I've found this method to be a quick and efficient way of finding out which component is faulty.... the tachometer or the regulator/rectifier. It sounds drawn out but really only takes a very short time to run through. If the water cooled regulator/rectifier proves to be faulty, don't put off replacing it as they have been known to catch on fire with disastrous consequences.
If that is the number it's a 2005 motor. There's plug on the back of the motor which is also your pee hole. Remove that plug and you can screw a garden hose into it for a flusher. And yes you can run them that way but don't go over a fast idle.
Thanks!
