Nissan 2013 6hp Jumps Into Forward When Started
jgreene
Engine starts fine but immediately goes into forward and I have difficult time getting it
back into neutral. Have to move shifter to reverse and then neutral.
Any suggestions?
Adjust the linkage. It's a 6mm bolt (with a 10mm head) accessed through the rubber grommet in the leg, that applies clamping pressure to the shift rod and cam rod via 2 beass blocks. Your dealer should be able to do it for you free under warranty. Typically does not go out of adjustment. If it was improperly adjusted after a wp service, or if the shifter was forcefully jammed into reverse when the motor was not running, that might do it.
