Had this motor since new. Compression 120/120. Rebuilt carb new points condensers plug wires and plugs. Changed coils in 1980's. Resealed lower unit and installed new water pump. Run 24:1 mix in tanks. Runs great. Lately have been getting excessive unburned oil discharging from water intake plate above cavitation plate and from little drain hole above gear case. Not used to seeing this. I pulled lower unit after running and found water pump housing covered in 2stroke oil/water emulsion. Inspected web between exhaust/drive shaft chamber for crack. None found. What am I seeing?
tony
tony
