Results 1 to 11 of 11
  1. #1
    Default Sears Eska Model 217-58560 3.5 hp Tecumseh
    Can't get this thing to run after hours of tinkering. I cleaned the carb to the best of my knowledge. And replaced the coil, condenser, points, spark plug. Sometimes it will fire for a second and then stop. I'm running about 40:1 fuel ratio. I disconnected the kill wire. It seems to randomly be getting spark.
  2. #2
    Join Date
    Aug 2010
    Location
    Bank of the Ohio river
    Posts
    138
    Default Re: Sears Eska Model 217-58560 3.5 hp Tecumseh
    The carb butterfly position can cause issue's wth starting, these little motor just needs the right amount of fuel and spark advance to run like a champ, do you have the Tecumseh carb/engine manual? PM with a e-mail addy if not
  3. #3
    Quote Originally Posted by MrCrabs View Post
    Update: holy hell I got the damn thing to run half decent. I gapped the points a little tighter .019" and really pushed them against the feeler gauge. It has been starting now and running half decent. It will rev up but sometimes sputter or hesitate on acceleration or decelleration. Just cutting out some. Dosn't like to idle all that well either. Screwed around with the carb adjustments a lot too. It dosn't even seem to want to start without the idle screw being about 2.5 turns out. The Main screw needed turned in to get it to rev clean. Gosh this thing is finicky. I'll take any pointers on how to fine tune this thing.
  4. #4
    Quote Originally Posted by unior View Post
    I had the same problem with mine and found out the end of the plug wire has that pushes into the coil is made differrent then most motors and was working its way lose thus no fire,i cured it by bread tying it under the flywheel so it couldnt shake loose.
  5. #5
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,743
    Did you replace the fuel lines? It just takes a little water in the tank to make you scratch your head and want to take a sledge hammer to it. Drain the tank into a glass jar and see if any water is in the bottom of the jar. Pull the carb and surface the flange on a glass table with 220 grit paper just pull it in one direction only until it all shines the same and make a new gasket. Do not over tighten the carb down just pull it down slow and even to good and snug. One of the biggest mastakes is using a old carb gasket and overtightening it down. It bends the ears on the carb and creates a vacuum leak. Probably why you cannot get a smooth idle. Your local lawnmower repair shop likely has the rebuild kit and gasket for that carb and some good fuel line. All the other parts can be looked up at sears parts direct just enter the model number to look up part numbers.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  6. #6
    Quote Originally Posted by kimcrwbr1 View Post
    I dont think your replying to me,because i said i had firing problem like the previous fella and i fixed it by getting the plug wire end to fit tighter i the coil
  7. #7
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,743
    Quote Originally Posted by Flyers16 View Post
    No I was not talking to you unior sounds like he has a vacuum leak to me?
  8. #8
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,968
    Flyers16 you need to start your own post,hijacking is frowned upon here,top of home page,click on thread tools
  9. #9
    Does anyone know the correct spark plug for the 3.5hp Eska???
  10. #10
    what year is this model?
  11. #11
    lol,if your offended by my question....to bad cry baby johnnygjr--this is a site for shared information...grow up!! hijacking,REALLY,BAHHAAAAA!!
Similar Threads
  1. Replies: 3
    Last Post: 07-30-2014, 05:47 PM
  2. Sears Tecumseh carb issues
    By ray_kane in forum Other Outboard Motors
    Last Post: 08-15-2011, 09:22 AM
  3. Eska Tecumseh CD Igniton Parts Source
    By ko4nrbs in forum Eska Outboards
    Last Post: 02-01-2011, 11:43 AM
  4. Eska tecumseh solid state ignition can you test them
    By eskaguy30525 in forum Eska Outboards
    Last Post: 04-10-2009, 01:06 PM
  5. Sears Tecumseh Ted Williams Issues
    By mmadden16 in forum Archive 2003-2009
    Last Post: 01-23-2008, 08:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
