Hello. My brother in-law has a 1986 Force 50hp outboard on a 14' Bayliner. He bought the boat a few months ago. He had a marina change the water pump and clean/adjust the carb. The boat ran really well until just recently. I replaced the rectifier since it tested bad and he was getting no battery charge. I also cleaned up all the wire connections since they were oxidized and fixed his throttle handle that the screw had backed out from. Now the boat will not go over 6 or 7 mph. In reverse or neutral the engine reaches top rpms since there is no real"drag" on the engine, but in forward gear the rpms stay very low. I detached the throttle and shift cables at the engine and manually shifted into gear. Then I opened the throttle plate up right at the cam. Still no rpms. I checked to be sure I have spark on both cylinders and I do. Any thoughts?
