Heres the issue. Boat will crank on first turn of the key and idle perfect as long as you want it to idle. I can even drive In idle as long as I want with no issues. When I throttle up it starts to bog down like its not getting fuel.
Here is my issue. I can prime the tank with the lines removed, and bulb immediately gets hard hook it to the motor and prime it and I never seems to get tight. However as I said above it will crank first shot an idle like a dream.
Should I look at fuel pump or carbs. not sure why fuel line bulb never gets hard. Is there diaphragm in something that could be busted?
