How-to replace battery cables on MK motor?
rodrigt
I sure would appreciate some advice on how to replace an MK motor’s battery cables from inside the controls housing to the battery. Problem is that my MK 40# Riptide came with only 5ft cables and for my 14ft canoe I need about 9ft. For context, my first splicing method turned out to be a dumb idea… I bolted two terminals wrapped with electrical tape but those joints now heat-up so much that it is very uncomfortable to the touch… Now that I’ve discovered the problem of course I could instead solder the joints, but I’m looking for something much better.
Question – Where can I buy a wiring assembly to solve my problem (wire 8 ga or preferably 6 ga)? Please see further details below – Thanks.
___________________________________________
PS - Details –
1- Having contacted MK support… “…we do not offer a longer wire, because if the wire is not long enough, a heavier gauge wire would have to be used on the extension to ensure that power is delivered to the motor efficiently. We would recommend 8 gauge wire be used on the extension. Use the plug set to attach the 8 ga. wire extension to the 10 ga. wire that comes out of the motor.” (Full speed amp-draw is 42A, thus 10 ga wire sure seems quite skimpy to me… but that is what comes with a 42A MK motor…)
2- MK’s connection method inside the motor’s control housing is a “quick disconnect connector" (female - about ¼ inch wide) which on the Internet seems rated for 10-14 wire ga).
3- MK's recommendtions for an added extension length of up-to 5ft is 10 ga wire.... (Geez, why bother splicing or using marine plugs... Why not simply replace the entire battery wiring set with at least #8 ga or, better yet #6 wire ga? )
4- Comment - On power boats recharging the trolling motor battery is no problem... But on a canoe the making sure one has enough power to get back (w/safety margin) is a big deal! (Doing the math on voltage drop with 42A on 9-10ft of cables is quite revealing...)
http://www.grainger.com/category/split-bolt-connectors/wire-connectors/electrical/ecatalog/N-8i3 i have used these....i would splice 8 gauge into the 10 gauge and try it...make sure to buy the copper ones and use battery post grease or spray ...
ideally replacing he whole cable with 8 gauge would be the way to go but you are going to run into fitting 8 gauge into a connector designed for 10 gauge...
10 gauge is designed for 30 amps but there is a big safety factor in the numbers on wire...your problem is where you feel the heat..you have a bad connection ...
you should be running a deep cycle battery.....they are designed to run down and recharge....it still decreases the life span but they can stand many more charges than an ''ignition'' battery...
Papyson thanks for your helpful comments. Indeed the .250" post quick-disconnect connectors used inside the MK motor housing only go to 10 gauge wire. After much fiddling I ended replacing the whole cable (9ft) with gauge 8 and cutting off the 6-or-7 strands that would not fit into the female connector. (At first I attempted soldering those strands to the outside of the connector, but that required using a torch and as I feared it annealed the connector and resulted in having no grip to the male post.) Also thanks for mentioning the battery post... I had been using ring terminals secured with wing nuts and I'm now replacing them with post terminals, incl brush-cleaning and spray. Certainly the worst problem was the bad connection I had made in extending the motor's 5ft gauge 10 wires with 4ft of gauge 8. Making the whole cable gauge 8 additionally saves a 0.2 voltage drop at 42 amps. I look forward to seeing what kind of speed increase I can get on my 2-person 14 ft canoe,
PS- Yes I am using a deep-cycle battery... A new Pro-27M from Interstate, with RC (reserve charge) of 180 (minutes at 25 amp draw)... Largest capacity I could find without going to extra weight of a Group 29 battery.
