Click for Chrysler parts and manuals!
Results 1 to 9 of 9
  1. #1
    Default Starter Rebuild Kit Chrysler 318
    Looking for a starter repair / rebuild kit for a 1976 Chrysler 318. The current starter is an Arco model 50109. Based on a few internet searches, the typical starter is an OSGR style.
    Any help is appreciated.
    Eric
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,389
    Default Re: Starter Rebuild Kit Chrysler 318
    You might have to adapt readily available brushes for other starters.
    Try looking for alternator/ starter rebuilders in your area.
    Jeff
  3. #3
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,468
    The Arco model 50109 comes up as a Bedix drive motor. I'd not bother with an over/haul.
    Instead, treat yourself to an inboard style HTGR/PMGR starter motor!
    http://www.marineengine.com/boat-for...nboard-Starter
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  4. #4
    Join Date
    May 2013
    Location
    Western Wahington
    Posts
    48
    Hey Eric,
    I have this starter brush set, insulators and stud left over from my Prestolite MDT-7021 and 7022 starters that I've rebuilt. I also have a 318 so I'm willing to bet that these will work in your starter. If you need more I can contact the rebuild shop where I purchased these and get back with you. Let me know I'll give you these for nothing.
    Russ
Name:	starter rebuild kit.jpg
  5. #5
    Hi Russ,
    I am looking for a starter rebuild kit for a 318 CW rotation. Not found one yet, wondering if I could get one from your shop?
  6. #6
    Join Date
    May 2013
    Location
    Western Wahington
    Posts
    48
    Quote Originally Posted by MeToo58 View Post
    Hi Russ,
    I'll look and see if I still have the kit you need. In the mean time could you send me the P/N of your starter? Thanks
    Russ
  7. #7
    Join Date
    Sep 2003
    Location
    Posts
    15,389
    Just changing the changeable parts does not mean the starter is 'like new'. A good rebuilder will rewire the fields as well.
    Jeff
  8. #8
    Quote Originally Posted by piper468 View Post
    Russ
    Hi Russ,
    Sure thing. The starter is model MDT-7021. It is a Prestolite starter on a 1974 318 marine engine.
  9. #9
    Hello,
    I just wanted to jump in on this...
    I have a 318 with a reverse rotation (counterclockwise engine) in a 1979 silverton.
    I think my starter just crapped out. It wont crank over and gets very hot. The batteries are good. Had them bench tested and they checked out fine..
    I am just wondering if I replaced my ARCO starter 2095509 (9 tooth counterclockwise) , would i replace it with the new IMI starter?
    does anybody know what is a good one or the right part number, I have been doing some searching and i think it is part LM318B, Could somebody double check that for me?
    And Ricardo, I did not forget about you I still owe you a tshirt, can you please PM me your address again so I can get that out to you?
    Thanks all,
    Eric
Similar Threads
  1. chrysler 7.5hp issues after rebuild help
    By spinelli006 in forum Chrysler Force Outboard Forum
    Last Post: 05-03-2014, 08:03 PM
  2. Delco-Remy starter rebuild kits??
    By mike77cj in forum Volvo Penta Gas Engine Forum
    Last Post: 11-30-2011, 08:01 AM
  3. 1980 75 hp Chrysler Skier rebuild
    By krceynar in forum Chrysler Force Outboard Forum
    Last Post: 07-28-2009, 07:43 PM
  4. Starter motor rebuild
    By royboy in forum Johnson Evinrude Outboard Archive
    Last Post: 09-20-2006, 11:10 PM
  5. 30L starter rebuild kit
    By russ0943 in forum Mercruiser Sterndrive Archive
    Last Post: 06-23-2006, 06:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
