We have a bf40a and it just quit....noticed a 10 amp fuse blown so I put in a new one...it popped as soon as I turned the key to run position.....i checked the battery connections and the negative was loose with some charing from it shorting....cleaned it up and tightened the connections properly...tried another fuse and it popped again. ..checked connection on starter and solenoid and it's all good....noticed a burnt smell on the wiring side of the engine and took off the control module and seen splattered solder behind it....so my question now was it a rattling loose connection that fried it or is there something else at work here?....do I get the new module and throw it in there hoping it won't pop...cause that's not a cheap gamble....
I also took apart the control and inspected the wiring in there and along the way back to the engine with no signs of any shorts.
Jason
Jason
