doc_stressor
A friend of mine picked up an older BF50 that appears to have been assembled from parts taken from several different engines. While it runs well, we found several wires disconnected from the harness both at the engine and the control unit.
We would like to test the overheat warning mechanism. The warning light does not light up on the control unit when the ignition is turned on. Is that normal on Honda's? Can someone tell me how to check out the sender, light, and horn so that we know that everything is working OK?
