Hi all,
I've been having some trouble with my 2003 15 hp pull start tiller steer, it starts and runs perfectly for 10-20 min then cuts out suddenly (as if the kill switch is tripped). It won't restart until the motor is completely cooled down, however if the spark plugs are pulled out then put back in it starts up straight away and will run for 5-10 min then cut out again. I've replaced the spark plugs, tested the kill switch, checked the wiring loom, coils, heat sensors, cdi ect... for continuity and correct resistance to no avail. I've checked the fuel lines for flow and contamination... all seems good. Inspected the cooling system... all good there too. I've seen in previous threads of similar problems but have not seen any that have resolved the issue. Has anyone got any suggestions?
Thanks,
Trent
Thanks,
Trent
