I posted this under Marine Power as well, I believe Mercruiser and Marine power engines are basically the same and see that this forum subsection gets more views and responses.
Hi everyone - I need some help and advice on some used Marine Power Engines that I recently purchased. They are 2004 4.3 V6 EFI VORTEC fresh water/Closed cooling with 600 hrs.
I'm know a bit about engines but mostly do simple maintenance and not sure how to proceed with this issue. I bought these engines about a month ago and was told they were in good working order by the owner and also the shop that took them out of the boat. The prior owner was upgrading to higher HP engines.
Once in possession of the engines I wanted to run them and change the oil since the last change was January 2013. I checked the oil level and that is when I noticed the oil was milky looking and much different than old oil I have seen before in my other engines. This is when I started to get worried and found thru research it was a sign of water getting I the system. I was hoping it could have been condensation from sitting or not being run up to full temperature or pressure washer cleaning or something. Here is where I am at now and symptoms.
1. Oil is milky colored
2. Under the oil cap was ice cream like gunk
3. When I hooked everything up to test run the engine they wouldn't start.
4. spark plugs are fouled looking and had some condensation on them.
5. Changed spark plugs restarted giving a little throttle and the engine started and needed throttle to keep going but shortly after would idle fine with no need to throttle. My understanding is no throttle should be needed with EFI engines. To start the engine now it needs a little throttle but once started idles fine.
6. After warming up a bit I drained the oil which is all milky brown.
7. New oil and filters
8. Pulled plugs on the starboard side of motor one was black, one was perfectly clean but had water on it and in it. The last was less black than the first.
9. Was hoping the condensation was just from them sitting or getting pressure washed changes in temperature but I am fearing that is not the case.
From what I have researched it could be the head gasket, exhaust manifold, cracked block, etc.
from theses symptoms is there any way to narrow down what the repair is? Definitely head gaskets? Definitely the exhaust manifold? Both or something else?
I am not really sure where to go from here and feel like I have been totally ripped off but also I should have known better and checked them out more thoroughly.
Tomorrow I plan to check the compression in all cylinders and see what that tells me.
If anyone has had a similar experience or has suggestions for narrowing down the problem that would be appreciated. If it is just the exhaust manifolds would change those myself, as i have done that on other engines in the past. Head Gasket is foreign to me so might have a shop make that repair.
