Hello, I have a 1996 Mariner 115HP Outboard... The other weekend we were heading into the dock when a loud beeping sound went off. I immediately knew it was my low oil indicator... I cut the engine and filled up the oil reservoir as it was low... I started the engine back up and the alarm still sounds... I have tried disconnecting battery thinking that may reset alarm.. I have banged the outside of the tank and motor around a bit hoping the float inside of the tank is stuck and needs jarred loose... Before replacing the tank I was wondering if there are any suggestions on what else I might try to resolve the beeping sound... Thank you in advance!!
