I have had a weak tell tale stream and was worried about overheating. When I replace the impeller I had a bunch of chunks in the housing area. I also had some weird looking worms in the end of my telltale. I removed the stat and it's stuck open. So I ordered a new gasket and stat. But I was wondering how the stat and poppet work? I also replaced imp and the top imp housing. I'm trying figure out where to insert a zip tie or some other tool to try and clean out any old impeller bits and pieces. Also I read that a person can remove the water tube from the bottom left of the block that runs to my fuel pump on the starboard side to aid in cooling. I'm not going to do that unless I understand how everything works. Any help or good explanation would be appreciated.
