I have a 1983 Mercruiser 305 the serial number is [FONT="]6218492. So far I have replaced the sensor in the distributor and the Ignition Module Thunderbolt IV. I have rebuilt the 2 barrel Rochester Carb and done a complete tune up on it. Here is what is going on now which I found after the carb rebuild because I was follow the procedure in the manual for after a carb rebuild as far as idle adjust and fuel mixture adjust. When I put the engine under load which for me is in gear at idle with throttle cable disconnected. I turn the idle speed screw to try to get my RPMs to between 650 and 700 what is happening is as I turn the idle speed screw I will get to a point when I get close to 650 where the engine speed will jump to about 850. What I have noticed is coincidentally the timing also changes which is why I replaced the Thunderbolt Ignition Module. So when it jumps up I then try and turn it down to 700 and when I get to about 700 it will drop below 600 and the timing will change too. If I leave the RPMs above 700 when I take it out of gear the RPMs not under load are about 1100 - 1200 RPMs If I l leave the RPMs low 550 - 600 under load I'm afraid it will stall going in and out of gear. I'm really lost hear. I'm not sure where to go the only thing I haven't changed is the distributor itself. If I change that and I still have the problem I'm done. Did I miss something? I have one other question there are 3 black wires coming out of the Thunderbolt IV module one is short and goes to one of the bolts that hold it on the manifold. Where do the other 2 go. When I bought the boat neither were connected so when I put the used one on I didn't connect the long two. It would be great it this was the problem but I doubt it. Any help would be greatly appreciated. [/FONT]
