Evening gents,
i have a 1990, 90 horse Mariner that when given good gas and a carb rebuild ran amazing. it hasn't sat for more than a week without at least a 15 minute run and flush and has about 20 hrs in the last 3 months on the water. today i replaced the battery, drained the carb(run to dry everytime in the yard), new fuel, plugs are clean. then! i turned the ignition and it was turning over but never made it to fire. i tried in about 5-8 second stretches and on the 3rd time the starter didnt kick over but i heard i whining noise so some thing was trying to engage. i checked the tilt-trim and heard the same noise. stepped away from the boat for half hour and tried again and the starter engaged and motor almost fired. tried again, same whining noise with ignition and tilt. then tried again and that stopped too. now nothing, no whining, no click. 20 amp fuse is good, battery is good, every fuse under the console looks good, ignition worked in the beginning. any and all troubleshooting ideas much appreciated.
