I have an older 1970 Mercury 500 50HP Thunderbolt outboard.
I seem to have two issues going on that cause me to have to fight my boat on the water a little bit. By fight, I mean it likes to drift to the left and or right and I'm constantly having to fight it back the other way.
The first one, which I think I know how to fix is that the steering cable connects to what I will call a ball hitch on the motor. It snaps over a small ball that looks just like a trailer hitch. That actually ball has movement in it, it has play. The nut does not appear to be tight enough but I tried to tighten it and it still has play. I'm thinking I need to shim it with a couple stainless washer?
So that bracket that the ball hitch mount is on I have noticeable play between that and the motor. When I hold the motor and have someone turn the wheel I can see the whole bracket start to move left to right without moving the motor. I have about an inch of play all the way across. About a half inch either direction.
Is there some type of rubber mounting in between that mount and the mount the motor pivots on?
Due to this play I notice that my motor shakes a bit too at idle.
Thoughts?
Thanks!
Thoughts?
Thanks!
