1978 mercruiser 120 hp gear oil leaking behind prop, pics included
drain the unit and split it. If there is oil on the driveshaft, the oil seal in the upper is bad.No oil on the driveshaft ,then the water pump base seals, shift shaft bushing seals or seal between the housings is not right
Thanks for the reply Bt Doctur, will do exactly that tomorrow..thanks again.
