I just acquired a used Honda 10 hp 4 stroke motor. I have gone through the carburetor and it looks great. The motor has 105 psi compression on both cylinders and the spark appears to be strong on both cylinders. The motor will start and run just fine at a higher RPM range, but as soon as it drops below fast, it just dies, no matter what adjustments I make. The motor is very clean and worth fixing, can you help me figure out why it won't idle?
Thanks,
Troy
Thanks,
Troy
