Hi. I bought my first boat which is a Boston whaler dauntless with a 1996 Honda BF40. Everything is great, except that the outboard dies at idle after I am cruising around. I attribute this problem to: losing my first trolling fish, and looking like a jackass when coming to the dock.
I'll try to describe all symptoms. All help is appreciated.
*Boat starts fine while in water or on muffs.
*I noticed that while starting on muffs gets my RPMs in optimal 900rpm zone, in water, RPMs are low, so I have to raise throttle ever to keep from stalling. I increased idle screw, and starting RPM is fine now.
*After startup and short warm up, boat runs fine, and has normal power through all engine speeds. The problem starts when I am cruising, then put boat into neutral. Boat will run fine for a short while (less than 1 min), then start to decrease RPM, then die.
*It is easy to restart if i have throttle lever up, and then put into gear.
*If i start up, then release throttle lever back to idle, then it will die again.
*While flushing the engine with muffs, it starts up ok, and runs ok without the idle dying problem, but after maybe 5 minutes, it will start to race to 2500-3000rpm, then go back to idle for a couple minutes, then repeat.
When I bought the boat, we took it out for a short run, and there were no problems. The next time i took it out by myself, i experienced the idle problem. No engine alterations were done between then. Seller did mention he added fuel additives. The only thing I can think of is that I filled gas between outings, and did not add additives.
After the problem, I changed all spark plugs (old ones looked fine), changes fuel filters, adjusted idle screw.
Things I suspect, and plan on checking:
Change oil
Change water pump impeller (never changed, but pees ok)
Engine electrical cutoff switch sometimes doesn't make good contact
If anybody has any suggestions on where to start, it would be greatly appreciated.
-Eric
Change oil
-Eric
