I have recently inherited the world's ugliest bass boat. My dad had a 1979 VIP H-17 Tournament which has a mercruiser 470 in it. That is not a typo it is an I/O bass boat. He passed away 18 months ago and I recently decided to get this boat back in the water after 14 years. My dad loved this boat and I really like the idea of fishing in the boat he loved. I have been around boats off and on but in reading the 470 forums it looks like I am in for quite an adventure. Here is where I am at so far.
Motor was rebuilt in 2000 not sure what all was done to it but it has 40 hours on it since the rebuild.
He had the outboard replaced around the same time as the engine rebuild
Spent $900 having the starter and coil replaced and all of the electrical gone through in June of 2014.
I put it in the water over the 4th of July and here is what I noticed right away.
Started great but took a few trips out to get it to where it would go over 2000 rpm. I attribute this to old gas because it eventually ran great.
Once started it has a good idle but after you give it gas will not return to a low idle unless you tap the throttle back to the idle stop manually. There is actually a tab on the valve cover with a hole in it that looks like it might be used to hold a spring that would help it return to idle. Any ideas or a part number would be appreciated.
Took it out again last weekend and had the following issue
The trim would not lower it would get to a point and stop. The trim motor sounded strong when raising but sounded bad when trying to lower. I then noticed the wiring for the trim switch located in the throttle getting very hot to the point where it was melting the electrical tape. I then noticed a trim switch on the console and that worked great to lower it but not to raise it. I am thinking it might be a relay.
After about an hour on the lake the motor just shut off. It will start like a champ but as soon as you take the key out of the start position it dies. If you keep it int he start position it continues to run. I would suspect an ignition switch but it was replaced when I had the new starter and coil put in less than two months ago. Any suggestions would be helpful.
I will send some pictures at the end of the month because the boat is located at the lakehouse about 5 hours away. I would really like to find someone that is knowledgeable about these engines that I could turn to for advice from time to time. I would be willing to replace the engine sometime in the future but the wife wasn't thrilled to spend $900 on an old ugly gold boat so no idea how much I would be paying to put a better engine in it. Thanks to everyone in advance for any help or advice you can provide.
