Just bought a boat with a 200 OX 66 2 stroke that is giving me problems when idling. When you crank the boat it will idle then sputter real bad and cut off. I have to pump the fuel hose to get it to stay on until I can rev the engine up to get it warmed up. when sputtering it will sometimes surge also. After running the boat at 3-4000 rpms it will idle fine but if I cut it off for 30 minutes or so then crank back up the sputtering continues. Any ideas on what this could be? Thanks in advance. Also, the alarm isn't working on the engine, how major is that to have fixed?
