Results 1 to 2 of 2
Thread: anchor switch
  1. #1
    Join Date
    Aug 2014
    Location
    florida
    Posts
    1
    Default anchor switch
    Hello everyone I'm new here just got a 1980 Corinthian 380 aft cabin for restoration project two questions. I have an anchor windlass but can't find switch to make it go up and down. Also no key switches for motors on fly bridge please help thank you. PS hydro steering at both stations turn but ruddersvdont move someone said a bicycle pump to charge system is this true? If so where do you pump it up at?
  2. #2
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,220
    Default Re: anchor switch
    Quote Originally Posted by csptain pops View Post
    1...... I have an anchor windlass but can't find switch to make it go up and down.
    2..... Also no key switches for motors on fly bridge please help thank you.
    3..... PS hydro steering at both stations turn but ruddersvdont move someone said a bicycle pump to charge system is this true? If so where do you pump it up at?
    1...... Find out if the Windlass motor switches control full current for UP/Down, or if there is a solenoid switching system with low current helm switches.
    2..... Same keys should also fit the upper station switches. If not... pull them and go see a locksmith.
    3..... OK.... you mention both "PS" and "hydro steering".
    PS is actually Power Assist steering using an engine driven fluid pump........ where as Hydraulic Steering is non engine related with the helm units being the actual fluid pumps.
    If Hydrualic, and if equipped with a Resoirvalve, there will be a shader style air fill valve on the Resoirvalve unit.
    Prior to charging this, check both helm pump fluid levels.
    There should be air purging/bleeding valves at the hydraulic cylinder line connections.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
Similar Threads
  1. anchor
    By bcclew in forum General Boat Repair Topics
    Last Post: 10-22-2012, 05:07 PM
  2. Is my BF50A just an anchor now?
    By upandatom in forum Honda Outboard Forum
    Last Post: 07-26-2012, 01:02 AM
  3. What size anchor?
    By wassajet in forum Boat Hardware
    Last Post: 04-14-2012, 11:59 PM
  4. Windlass anchor problem
    By chriscraftcat in forum Chris Craft Engine Forum
    Last Post: 08-01-2009, 11:20 AM
  5. 2002 350 MPI no start after anchor
    By bsproul in forum Mercruiser Sterndrive Archive
    Last Post: 07-09-2009, 12:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
