golfergator
Hi,I am new to this forum. I was out in my pontoon boat this weekend 7/26/14, and going back to the dock to load the boat up on the trailer, it just shut off. I was going no more than 5 mph. I had to get towed into the dock, because the motor would not turn over. At that time, I didn't know if it was the starter... I took the starter out yesterday and it works fine. So something is froze up somewhere. It is a 1999 2-cycle Evinrude 115. It has plenty of 2-cycle oil in the reservoir. It did not even hick up or struggle, when it shut off. I am hoping that the motor did not seize. Can it be in the lower unit gearing, that is keeping it from rotating? Does anyone have any suggestions, on how I should troubleshoot this thing, before I just start ripping through things. I am thinking of taking the heads off, to see if the cylinders are scored, and would not mind starting with the lower unit, if it can be a possible cause. Any help or suggestions would be very welcome. Thanks, Gator from Helendale California!!!
