Results 1 to 2 of 2
  1. #1
    Default Stromberg 175 CD2 carb. setuup:
    I recently purchased rebuild kits for twin Stromberg 175 carbs. from a Volvo Penta AQ130C engine but I have been unable to find the float settings. Can anyone help me with that information. Thanks
  2. #2
    Default Re: Stromberg 175 CD2 carb. setuup:
    I know i play necromancer here and the OP is probably long gone... but it might help other as the information might be hard to get.
    the Stromberg-Zenith 175CD 2s ( probably part 3098 R and F, for front and rear) the float need to have a height of 15,5 to 16,5 mm for a hollow float and 18,5 to 19,5 mm for a black solid float.
    that can be ajusted by slightly bending the tap on the float, be care not to deform float frame ( each side of the float need to be at the same height) using 1 additional washer with the needle valve can also be used to raise the float
    also fuel pump push between 1.5 to 3.5 PSI if you upgrade you fuel pump to electrical ( connected to oil pressure sensor) be care to use a fuel pump that match these pressure ( look for this part number: airtex E8251, a 2.5 to 4.5 psi marine pump) and use a fuel regulator like the Holley 804 that is factory setted a 2.7 psi .
Similar Threads
  1. Looking for carb set for 125hp 1985 force plus carb question
    By Longislandboater in forum Chrysler Force Outboard Forum
    Last Post: 07-20-2014, 07:43 AM
  2. solex44pa1 carb need ball valve or new carb any ideas? thanks
    By mr moon in forum Volvo Penta Gas Engine Forum
    Last Post: 07-30-2012, 04:25 PM
  3. Replies: 8
    Last Post: 06-13-2011, 07:02 AM
  4. Mariner 40hp Twin Carb 1985 VS Mariner 40hp single carb 1998
    By Commando C2 in forum Mercury Mariner Outboard Forum
    Last Post: 05-10-2011, 09:43 PM
  5. Carb Tuning 1993 185 OMC Cobra Holley Carb
    By jmcmusicman in forum OMC Sterndrive and Inboard Forum
    Last Post: 06-13-2010, 07:59 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
