mikestephsasha
I have an electrical question , I have 1200 hrs on a 2002 Honda 225. It has been running great and continues to run great however. I got my lower unit stuck on a lobster pot and i used the trim to get the lower unit out of the water to get line off. the trim was under a little strain but not much. When I went to start it again I turned the key to do the system check and no beep , the battery light was on, i turned the key and it started and ran fine. I got to my mooring shut off the engine and then the battery switch. I turned the battery switch back on and it beeped twice (without turning the key) like it was doing a system check . I shut off the battery and pulled all the fuses on the engine to check to see if i had blown a fuse, all were good. Turned the battery on again (beeps went away) turn the key and got the 2 beeps again and started fine, called it day.
I returned 2 days later. It initially worked as it should .I shut it down at the end of day and tried it again to make sure, same double beep as i throw battery switch but starts fine.
I'm going to check battery connections today but any other ideas are appreciated.
mike
mike
