2004 honda 130 wiring question
surfnfisher
Just got a used honda 130. Is there a wiring diagram on how to hook it up? Which is power wire? Black with white stripe? Etc.. Thanks alot
you have only two wire coming out from the engine, one wire goes to starter motor (original wire black with white stripe) that is positive(+) other black wire fixed to the engine block body that is negative(-) . just trace the wire and see.
and you will have two wiring harness, that will not make prob for you.
wajira
