kghost
Silver Medal Contributor
I have been working on a 1994 350 mag fresh water cooled mercruiser Alpha I Gen II
Used in fresh water only
Boat had a boat load of issues due to bad workmanship and total moranic work.....
The last thing I was chasing was a over heat issue.
1. No gauge reading...............lost thermosts housing ground continuity for sending unit. FIXED
Tested sending unit appeared to be wrong based on a 143 or 160 degree thermostat.........or so I thought.
After changing sending unit temp still climbed over 200*......SH!T
Took thermostat housing off and looked at thermostat...............
Some F'n moron put in a 198* thermostat in this motor.................
The thermostat housing is a one piece, 6 port with OUT the spring ball set up as referenced by the manual.."later models"
Question because it did not have the original thermostat would anyone have any idea which one to replace it with?
A 143 or a 160 and if you could explain why you suggest one over the other.
