Any help I can get with this- Thanks in advance!
1989 Carver 2357 Mercruiser 260 -
Last year 4300 rpm W.O.T on the water.
Bought a low hour Alpha One lower unit and replaced over the Winter - and yes I'm using the prop original to the boat. Old lower functioned fine but was corroded. I'm still using my old upper. First 2 trips on the water I could get to 4300 rpm. Now I'm only getting to 3000 rpm and top speed of 15 mph.
I added the outdrive swap info but here's what I've done so far to remedy the 3k max:
Checked for carb linkage operation at W.O.T, new Quadrajet carb, new Sierra fuel pump and both inline and spin on filters,replaced fuel lines from carb to tank as well as a new pickup and anti-siphon. I've also ran the boat without the gas cap for ventilation. Old carb was originally thought to be the issue. I also removed the water shutters in the exhaust to eliminate a restriction possibility.
Replaced plugs with Delco MR43T's gapped at .035, new cap,rotor and wires with Mercruiser numbered parts on the Thunderbolt 4 dist. Nothing changed. Still 3k max.
Yesterday I upgraded to a Delco Voyager ignition- regapped plugs to .045. Still only getting 3k rpm. I'll add that the boat runs great at all speeds up to and at 3k rpm- but it's maxxed there. I have yet to do a compression check.
Anyone see anything I've missed???
