I have a nov 2006 Mercruiser 4.3mpi v6 engine that I have owned and serviced from new. The engine has covered around 600 hours and been used on a 23' Karnic 2260 walkaround with an alfa gen11 stern drive.
Plugs were changed Oct 2013 together with oils and filters, First trip out this year was yesterday after standing since Oct 2013. All went well from an engine point of view and cruised around 3 hours at 3000 rpm faultlessly.
Today I start up and travel out of marina to open channel at tickover. However upon acceleration to planing the engine lost power and started to misfire if over throttled. I stopped the engine and restarted and it ran great without any load on. When drive is engaged at tickover and up to 1500rpm the engine runs normally. to get onto the plane this boat requires 3000 rpm and at this point the engine cuts the power and goes into what I guess is 'Limp' mode. once in limp mode it will not increase the revs until the engine is stopped and restarted again.
I know this boat and engine as I carry out all my own maintenance, however maybe I will need to take it to a mercruiser dealer to diagnose, unless anyone can offer any help.
NOTE
The dash board Temperature gauge has failed during the winter storage and is reading hot, even when the engine is cold, although this did not affect the performance of the engine on yesterdays 3 hour cruise.
Please help if you can. Thank you.
NOTE
