Good morning guys. I am having a loss of power on the top end of my 71 50hp Evinrude, model 50173S. The motor starts good hot or cold. Idle and low speed operation is good. I began noticing the power loss towards the end of last boating season (we are in North Dakota). With just myself in the boat it would get up and plane but seemed a little slower than normal. With a second person on board it seemed a bit slower yet. Put a third person or more in the mix and she was just plowing water, seemingly lacking the power to try and get up. The motor sounds like it's really trying but not gaining the RPM's to get there. The kids wanting to go tubing and it really laid an egg on that one, just struggling the whole time. Then last weekend we had been out fishing, motor ran fine other than high end power loss and on the return trip to shore I started motor, let warm up a while and cracked the throttle. Motor barely moved the boat sounding like a sick cow. I thought ok so I'm on one cylinder now. We idled into shore and I had my son drive the truck to the boat ramp and I began limping over to it. I wasn't sure if I should continue trying at WOT but gave it a try. About half way to the ramp it began doing a quick lurch here and there and all of the sudden it hit both cylinders and I was up and running, but still without peaking out at my top end RPM's. I realize it's only a 50 horse but this motor used to get up and pull two water skiers no problem and currently won't hardly pull a seven year old on a tube!
This spring carb kits were installed and a good cleaning done on both. Fuel pump was new last season. Spark jumps a 7/16 gap and compression is 120 on both cylinders. I tried squeezing the primer ball when WOT on the lake with no change. I talked to the local boat mechanic and the ignition system was brought up suggestion maybe a coil pack is causing this lack of power showing good spark in open air but maybe is just weak enough in the cylinder for a lack of top end RPM's, or that the power pack is dropping a cylinder at times. Any ideas or suggestions anyone might have is greatly appreciated. Thank you!
