Please help, I am at wits end with this. Engine starts and runs fine at the dock for 4 to 10 minutes before fuel pump fuse blows. Gas is clean with no restrictions. Filters are brand-new. Low-pressure pump replaced last year. High-pressure fuel pump just replaced a month ago. Boat ran great after fuel pump was replaced last month on a 20 minute test run. It sat for two weeks, and now having this problem every time I start engine. Fuse and fuse block (the side of the fuse block where the fuse is) just gets hotter and hotter until it finally blows. This running at only 1500 RPM at dock. Just had fuel cleaned, so know it is not a fuel issue. Can somebody please lead me in the right direction? Thank you!
