Ruan Urquhart
Hello,
I recently aquired a mariner 8hp outboard and have been having troubles with it.
In order to start it you must give it some throttle, however there is a mechanism that prevents you from giving it any throttle when in neutral, so you must put it in gear, but when you put it in gear it locks the pull cord, so you must take of the hoode, disconnect a rod, give it some throttle and pull it many times at varying throttle positions, and once it starts you then need to throw it into neutral again otherwise it creates a lot of wash in the bin that it is sat in, where it often cuts out because you cant give it any revs. I have been running it in a large wheelie bin but even after a few seconds running the water from the tell tale ( which is a very weak spluttery flow ) begins to heat up very quickly. Not scaldingly hot, but definatelly too hot.
So far i hate this outboard compared to every other one I have ever owned. You cant start it in gear without taking the hood of and disconecting thing, you cant give it any throttle in neutral, and there is a twisty dial sat beside the tiller that is for adjusting the idle speed i believe and it can also be pulled out to turn the choke on. Why can the idle setting dial be somewhere hidden where you arent likely to adjust it be accident?
So in short could somebody please give suggestions on how to get it to start without needing any throttle, and as to why the pee streem gets hot very quickly and has a weak flow? ( although im guessing a bad impeller for the weak stream part )
Thanks for your time,
Ruan
Ruan
