Hi ,Its been awhile, but I need some more help with this 93 3.0lx. It's on a 25" pontoon and stubbles or misses when shifted passed mid throttle. Its got a rebuilt carb, new fuel pump, coil, plugs, wires rotor, and cap. Timings was checked three times and is correct. Checked all fuel filters (on pump and carb) and found no trash or water. Checked pick-up tube and anti- syphon valve, and breather tube on tank. Fuel line is clear and tight. Have no changed separator filter yet. Considering tearing into rebuilt carb o re-check float height and check for trash in jets. Plugs are NKG BPR6EFS, and where supposed to be a cross over to what I wanted. Al check's were this week, but boat has sat for almost year since all these parts were replaced and tried out on lake just last weekend. Compression was around 145 on all cylinders last fall if I remember correctly. Could these new parts have gone bad in less than a year? Engine will fire right up and idle great. Just Boggs when throttle is pushed passed mid way. Fixing to check pressure on pump next, and change water separator filter. Then open the carb up. Any idea's? Thanks for any help..
