Mike Thibodeau
My frame is BBBU-4000400's and I'm looking at a lower unit from BBBU-1000000's
reading the year charts makes mine a 99 BF90AX and the donor a 97 BF90AT
I can't find if they would match up.
The 97 is a smaller capacity and it's visibly a little different too.
but I only have pictures to go from
Any idea?
Why the swap?
when I shift it doesn't grab hold and chatters at low speed.
I've adjusted the cable which was part of the cause but damage is done.
I just want to get back on the water.
I prefer to learn to rebuild my gear case but summer is fast passing me.
i changed the gear oil month back and just dropped the lower unit, it shifted fine with plier on the shift rod. Then reinserted it. As I was doing so gear oil leaked out the inflow screens.
So I've definitely some work in front of me to replace gaskets, seals, and water pump and potentially dog gear.
Should i I just take th lower unit to the nearest honda marine tech?
My original is on left, with the toolbox.
Any idea?
Why the swap?
