nohasslekindaguy
Hi, new member here. I have a 1989 Evinrude 25 long shaft with remote controls. The engine starts relatively easily when cold, and runs fine. It seems when it warms up I have problems. If I accelerate gradually, it runs erratically and vibrates and sounds like it's running on one cylinder. Obviously performance suffers. Then, if I give it full throttle, it has great acceleration and it runs smoothly. I'm thinking it's ignition related, but I don't have the special test equipment the manual calls for to test the electronic components. The motor has great compression. I rebuilt the motor with new rings and an oem gasket kit. The carb was cleaned and rebuilt with an oem kit as well. The plugs look like new and the plug wires are new. I installed a new water pump and thermostat, so I don't think overheating is an issue. I only use ethanol-free fuel. I've heard the power pack is a common problem. Does my issue sound like that? I am considering replacing all of the ignition components with new, but that may be silly. If anyone has anything else I can check, please post. I appreciate any help.
Marty
Marty
