Danny Wheeler
Ok I bought this Lowe pontoon boat yesterday. We have no boat mechanics for 145 miles. I pulled plugs fogged cylinders. Pulled carbs cleaned them. Cleaned tank and replaced the fuel lines. New battery. Cranked up on first kick of the key runs great now the bad I cannot get the engine to shut off. I disconnected the battery. Pulled the kill switch I even pulled the wire from the kill switch off the ignition switch and it keeps on going. I finally pulled the fuel line off and let it run out of gas. I do have a hose running water at medium pressure. Water pump works. Any ideas how to fix this. I probed the kill switch with my multi meter that beeps when wires have a good connection and weather the kill switch is engaged or disengaged all wires beep so it seems they are all connected all the time. But I thought if I took that black wire off the ignition that would break the chain. This is my first boat any help would be appreciated. Thanks in advance
