Melvin Hall
Have tested the battery voltage before starting the engine, 12.9v, it did not raise when running the engine at idle or at full throttle, so have come to the conclusion it is not charging.
If the most likely problem is with the rectifier, I would need help identifying it and how to test it?
Any help would be much appreciated, thanks.
