I recently purchased a boat with a Johnson 1970 60hp outboard motor. The boat was sitting for 3 to 4 years and I took it out and ran it on the water for a hour or two and the boat stalled and would not run. I replaced the fuel pump all lines and took apart all 3 carbs and cleaned them. No sign of anything being gummed up. I also replaced the plugs and ran the boat off my neighbors tank and hose still no luck. It seems as when I run it at home its fine as soon as I go put it in water it won't run under a load. Seems also like its getting back pressure in the fuel line when I take one off after it stalls it has a lot of pressure in it.
