I doubt it is the riser/elbow........It is very common for this issue as I said in your other post/topic.
Question, when you pressurized the stuff, which was perssurized? the fresh water or antifreeze area?
From what I remember when I had ran into this exact issue, the exhaust manifold was bad..........Get new one and enjoy the boat.
If I remeber the exhaust manifold does three things,
exhaust from motor
fresh water to elbow
antifreeze as part of the closed cooling
So if water or antifreeze is getting into the motor this is typicaly where it comes form.
A flat plate over the elbow/riser location is how to pressure check the manifold.
Do not fret over why water gets into # 4 cylinder.................it is what it is...........be glad you found it early enough.....the next issue that would have occurred would have been severe water in the oil and # 4 push rods would bend and possibly a valve due to water in cylinder.......Been there done that.
