how to set the timing?
jbo225
Hey everyone new to this forum have my first question I have a 1994 Yamaha 6hp 2stroke short shaft was wondering how to set the timing on it thanks for any input
I'm guessing so the motor wouldn't start has good compression getting spark and gas was running and cut it off then wouldn't start again I put new plugs in it so my uncle said check the timing?
you can check the ignition timing, but for the you need ignition timing light ignition timing at idle BTDC 5' +- 3' .
How plugs are look like ? may be fuel mixture is not correct.
