Results 1 to 2 of 2
Thread: Hull Poslishing
  1. #1
    Default Hull Poslishing
    Hi,
    I have a 17 foot Fibreglass Cabin Boat. The tops sides of the hull are regularly polished, however, the underside has never been. It is still in excellent condition.
    The boat is stored on a trailer, and almost always used in fresh water. There is no growth or anything like that.
    What process should I use to get this cleaned up? Does it just need a good cutting compound?
  2. #2
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,832
    Default Re: Hull Poslishing
    I'm assuming that the fiberglass is coated with gelcoat, which makes it smooth and easy to polish. If so, any NON_ABRASIVE cleaner will likely work. Best to use a cleaner specifically made to clean and polish gelcoat. Then a good wax job on the whole thing.
    I've had very good results from the Star Brite Hull Cleaner and the Star Brite wax with PTEF. The PTEF is some type of polymer that does a great job and leaves a very slick finish. Once you have done the first coat with the PTEF, wait about two or three weeks and do a second coat and it will last an entire season.
    CHawk 25 DLX
Similar Threads
  1. tri hull boat
    By ringo111 in forum General Boat Repair Topics
    Last Post: 11-14-2011, 06:00 PM
  2. Hull Repair - Self or Pro?
    By johnmedic in forum Boat Hull, Deck and Transom Repair
    Last Post: 09-18-2011, 08:18 PM
  3. Paint the hull or not
    By briang0 in forum Crusader Marine Engine Forum
    Last Post: 01-22-2010, 11:06 AM
  4. Sea Ray Thru Hull
    By wickeral in forum Mercruiser Sterndrive Archive
    Last Post: 06-04-2009, 12:40 PM
  5. Hull Id #
    By stewsbs in forum Volvo Penta Gas Archive
    Last Post: 05-19-2008, 01:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
