Recommended oil and plugs bf200
Skooter
Advanced Contributor
I have a 2003 Honda 200 and going to do some maintenance.. what is the recommended oil and spark plugs for this...thanks
Engine oil,I am Using Honda 10W-30 ,but some of them still using 20W-50 also.
One Spark plug pull out and see is that the normal or iridium plug,
part numbers you can get from boat.net
wajira
Use ONLY the iridium tipped NGK IZFR6F11 in that engine. Any others are trouble waiting to happen.
Manual calls for 10W-30 oil. Change oil and filter every 100 hours or every season, whichever comes first.
if it is iridium tipped NGK IZFR6F 11 , plug gap 1.1mm. that can't adjust. this plug you can use 400 hrs and replace.
Skooter - As Wajira said, the iridium tipped plugs are not adjustable. If you bought the type of plugs that have an adjustable gap, you've got the wrong ones. The electrode on the iridium tipped plugs have just a sharp point.
I got the ones that were recommended by you and the helm, NGK IZFR6F 11, but the book says from .040-.043. So are they all pregapped?
