Alright, I took the lower unit off, and hooked a drill to the driveshaft. If I have both copper tubes in the impeller housing, with the unit in the water, above the impeller, I get nothing coming out of the outlet tube. It just spits a little, but no continuous flow. I'm assuming that this may be normal as the return tube is allowing air back into the impeller not allowing it to pressurize. If not let me know! If I remove the return tube, and at the same depth in my barrel, water flows continously out the outlet tube. If I put the return tube back on, and with both tubes in while I submerge the lower unit, till the water is just below the opening of the tubes, I still get no water out the outlet tube. So same as when the water was "just" covering the impeller housing. I put the motor back together, with the return tube not connected, and with the outboard(which is attached to my boat) in my barrel, and the thermostat housing cover off, I get no water out the housing. Remind you that the water level is approximately 3"-3.5" above where the lower unit mounts to the outboard. I'm assuming that it is because of the depth of water in my barrel, that it is not covering the impeller appropriately enough, and not supplying enough water to flow up the outlet tube. Due to the motors mount to the boat, I can't lower the unit into the barrel any further. I attached a hose to the outlet tube, when I had the tube attached to the motor, and water flows out the T-stat housing uninhibited, out the left hole. (There are three in the housing-middle one has the spring/ball under the T-stat) Just looking for an opinion, but do all signs point to the motor just not being deep enough to allow water to properly cover the impeller in the barrel for a successful impeller test? Is there any harm in not running the return tube to the impeller when running it on the boat on the water? Or should I put it back in, when I test it in an actual body of water? I'm just trying to make things are in order before I launch her.
